  3. Passing variables in ipcBeginProcess
  • Views 15980
Prakash Shenoy
Prakash Shenoy over 11 years ago
   I am using ipcBeginProcess to do a comminication between CIW and unix shell. When the process is done, I am calling a post function. Now the problem is, I want to use few variable from the procedure where this ipcBeginProcess is called.
Example:
procedure( prog1()
let(aa,bb,cc
id=ipcBeginProcess(command "' "" """ prog2)
procedure(prog2(id status)
print(aa)
I want to use variables aa,bb,cc that are local to prog1 in prog2. How can I do it?
Prakash.
    Hi Prakash,
    Some code to allow passing "user data" to the callback function can be found here:
    Another version of the code (the only difference is that it uses my "ab" prefix rather than "CCS" for Cadence Customer Support, plus a comment about SKILL++ is missing) can be found here:
  • Prakash Shenoy
    Thanks a lot Andrew. It worked very well.
    Prakash.
