  3. OCEAN scripting question
  • Views 14963
archive over 20 years ago
I'm a bit new to OCEAN, but understand that it falls in the category of SKILL.
Very often, in Analog Artist I will use a distributed processing option.  When netlisting, a popup dialog provides options for the distributed processing including an option to allow the job to be reused.
Now I have searched across the ocean documentation, and can't figure out how to properly set this option when using distributed processing in an ocean batch script.  Can anyone here provide some insight?  Thanks
Originally posted in cdnusers.org by superm1
    The best you can do right now from OCEAN is to explicitly call the deleteJob() function once you're done with a job - this would allow the job name to be re-used.
    In IC5141 USR4 (due middle of September), PCR 664043 is being fixed such that the deleteJob cdsenv setting will be honoured during OCEAN submitted jobs. This means that:
    envSetVal("asimenv.distributed" "deleteJob" 'boolean t)
    This is the same cdsenv setting that is used to control the Reuse job name after completion checkbox on the submit job form in ADE.
    Originally posted in cdnusers.org by adbeckett
