  3. skill code for working with internal entities via IPC
  • Views 14848
archive over 20 years ago
Is it possible to take an internal object, write it to a string, store it in an internal program, then re-use that value in
a Skill program?
For example, if I do this:
rc = ddGetObj( "00test1" )
dd:0xacb0168
to get a library reference stored in variable rc, can I write the value of rc to a string and later recall that value (perhaps
storing it in a completely different variable) to access the same library?  In other words, what I would like to do is
something like this:
myIPCwrite( rc )        to save the value of rc to an extneral process
lib1 = myIPCread()    to recall it
(this could also be referred to as marshalling and unmarshalling a value)
Originally posted in cdnusers.org by gry
    No. You can't do this.
    Objects are created in VM in each session, and the IDs cannot be re-used in different sessions. Some objects (dd object for
    example) you should be careful about storing long term, since things may change...
    Regardless of this, even within the same session, you cannot convert the print value of a object (such as a dd object
    or db object) back into the actual object reference itself.
    What you should write is the information about how to recreate the object - i.e. the library name in this case. There's
    no harm in doing another ddGetObj after reading the library name back later.
    Originally posted in cdnusers.org by adbeckett
