  3. schematics addTitleBlock and LayoutXL : triggering ques...
  • Subscribers 150
  • Views 14483
schematics addTitleBlock and LayoutXL : triggering question
samung
samung over 11 years ago
I have an issue with the titleblock generation in schematics and layoutXL.
The issue is the folowing :
The titleblock is generated in layout (this not wished at all) in the case:
1-Open schematic via library manager. The corresponding layout must be closed.
2-In this schematic , menu Launch > Layout XL. The titleblock is generated in layout just opened.
In my automatic titleblock generation script, I have a "deRegUserTriggers" line :
deRegUserTriggers(
t_viewType
[ s_appTrigger [ s_menuTrigger [ s_postInstallTrigger ] ] ]
such as :
deRegUserTriggers("schematic" nil nil 'CCSaddSchTitleCell)
My understanding of the issue is that the "t_viewType" for a layout view can be in some specific conditions "schematic" ?!!
Would you have a way to avoid triggering the execution of the CCSaddSchTitleCell procedure when the layoutXL is launched ?
Thanks a lot !!
P.
  • theopaone
    theopaone over 11 years ago
    The viewType determines how the tools address the data. When the viewType is schematic, it is expected to be instances, notes and connectivity, the logical view. When the viewType is maskLayout, it should contain physical data. If you have layout data in a schematic viewType (the view name can be anything), the tools will treat it like a schematic and you may not be able to execute layout tools. Layout XL should never open a view named "layout" as a schematic viewType, if it is, there is something wrong with your setup.
