  3. Text or Name used for Metal Layer using tech file
  • Subscribers 150
  • Views 15952
GyanL
GyanL over 11 years ago
Is it possible to get the text / name used for METAL layers using techFile or any other variable.
E.g. In some technology M1 is used for defining METAL 1 layer
, similarly I came across METAL1, MET1 etc.
Please help.
Gyan
  • skillUser
    skillUser over 11 years ago
    Hi Gyan,
    Here's a brief example, (assuming that you have a cellview open, for getting the tech file database ID):
    tf = techGetTechFile(geGetEditCellView())
    metals = setof(lay techGetLayerFunctions(tf) member("metal" lay))
    =>  (("Metal1" "metal" 27)
        ("Metal2" "metal" 29)
        ("Metal3" "metal" 31)
        ("Metal4" "metal" 33)
    ;; or if you just want the metal layer names:
    metals = foreach(mapcar met setof(lay techGetLayerFunctions(tf) member("metal" lay)) car(met))
    => ("Metal1" "Metal2" "Metal3" "Metal4" ...
    These happen to be in order because they are in order in the tech file - your mileage may vary, but I would expect similar ordering...
    Hope it helps!
    Lawrence.
  • GyanL
    Lawrence,
    Thanks.
    This is what I was looking for. Thank you once again.
    Gyan
  • GyanL
    Lawrence, Do we have any option to get min and max width rules for all the Metal ?
