  3. How to Edit rod Subpart connectivity using SKILL function...
  • Subscribers 150
  • Views 15422
How to Edit rod Subpart connectivity using SKILL function ?
San
San over 11 years ago
I have MPP guard ring object.
I found commands like rodAddSubPart(rodObjId subpartType list(parameters)) and rodDeleteSubPart(rodObjId subpartName)
But I am not able to find any command for editing an existing subpart object parameters.  I just want to set my rod Subpart object's "Connectivity" to "Net".
  • theopaone
    theopaone over 11 years ago
    Once the mpp is created you can access subParts with rodGetSubPart. I think you can also use the ~> functionality, mpp~>subParts, but I'm not able to test this right now. Once you have the subPart, it may be a rodObject so you will have to add the net to the dbId rather than the rod object.
