  3. Need help in Creating via at overlap of two metal layer...
  • Subscribers 150
  • Views 18374
Need help in Creating via at overlap of two metal layers
Bhawna1
Bhawna1 over 11 years ago
I wanted to place via in overlap area of two metal layers. For that, I created a layer at overlap by using leLayerAnd function.
Created VIA array by calculating width length of the layer. I Need to do that for all the overlap layers present in the cell.
lFrom eLayerAnd function, I got a list of bBox of all overlap layers.
Now I want to repeat the function for all overlap layers. But dont know how to access that list of bBox.
Code I used is :
cv=geGetEditCellView()
OVERLAP_LIST=leLayerAnd(cv list("M1" "drawing") list("M2" "drawing") list("marker" "warning"))
OVERLAP_BBOX=OVERLAP_LIST~>bBox
BoxWidth=caadr(car(OVERLAP_BBOX))-caaar(OVERLAP_BBOX)
BoxHeight=car(cdadar(OVERLAP_BBOX))-cadaar(OVERLAP_BBOX)
COLUMNS=int(BoxWidth/0.142)
ROWS=int(BoxHeight/0.142)
dbCreateViaShapeArray(cv "V1" nil caaar(OVERLAP_BBOX)+0.017 cadaar(OVERLAP_BBOX)+0.017 0.142 0.142 0.05 0.05 ROWS COLUMNS)
This code is working for only one overlap layer.
Can anybody help to repeat this for all metals.
Bhawna
  • theopaone
    theopaone over 11 years ago
    You need to get a little loopy to do this {8^)
    Code is not guaranteed to work.
    ;; Set up a list of layer pairs and via.
    layerList = list( list( list("M1" "drawing") list("M2"  "drawing") "V1") list(list("M2" "drawing") list("M3" "drawing" "V2) ... )
    cvId = geGetEditCellView()
    ;; Now loop through that list
    foreach( layerSet layerList
        overlapList = layerAnd( cv car(layerSet) cadr(layerSet) list("marker" "warning") )
    ;; Loop through the overlapList
        foreach( shape overlapList
            box = shape~>bBox
    BoxWidth= abs(xCoord(car(box)) - xCoord(cadr(box)))
    BoxHeight= abs(xCoord(car(box)) - xCoord(cadr(box)))
    dbCreateViaShapeArray(cv caddr(layerList) nil rodAddPoints( car(bBox) list(0.017 0.017) 0.142 0.142 0.05 0.05 ROWS COLUMNS)
        ) ;foreach shape
        geDeleteAllMarker(cvId)
    ) ; foreach layerSet
    You can put the overlaps and via size and spacing into the list as well if they are different for each via.
