  3. Saving a structure to a file and reading it back ?
  • Views 15152
archive over 19 years ago
How do I save a user defined structure (by using defStruct) to a file and how do I retrieve it back ? Can I just use outfile( ... ) and fprintf ? Thanks, Michele
Originally posted in cdnusers.org by micheleq
    Not directly. It's easy enough to write something that would do this though - for example, the following writes out a SKILL statement to recreate the structure (note, it doesn't assign the result to a variable, so you'd need to adapt it to your needs).
    procedure(ABwriteStruct(file struct)
    fprintf(file "make_%s%L\n" type(struct)
    foreach(mapcan arg struct->?
    list(concat(? arg) get(struct arg))
    Originally posted in cdnusers.org by adbeckett
