  3. Recursively assign ?callback entries when creating a new...
  • Subscribers 150
  • Views 16749
Recursively assign ?callback entries when creating a new pull-down menu using hiCreateMenuItem()
Pacher Luca
Pacher Luca over 11 years ago
Dear SKILL users,
This is my first post on the Cadence IC SKILL Forum so I will try to be as precise and exhaustive as possible. I'm trying to write a SKILL script to add a new pull-down menu in the main Cadence Virtuoso Command Interpreter Window (CIW) and enable faster access to process and IP libraries documents in PDF format that come with the CMOS fabrication technology we are working with.
I know basic SKILL language programming and syntax. As a starting point I followed the code skeleton proposed in the well-known post
http://community.cadence.com/cadence_technology_forums/f/48/t/15213
Basically I want to:
1. define a SKILL list e.g. PDF_DOCLIST that stores absolute paths to PDF documents that I want to open from the newly-created pull-down menu using a (selectable) UNIX PDF viewer e.g. "/absolute/path/to/process/design/rules/filename.pdf"
2. define an auxiliary SKILL list e.g. LABEL_DOCLIST containing for each entry in the previously declared list the corresponding meaningful and human-readabe text label that explains the content of the PDF document that I want to access e.g. "Design Rule Manual (DRM)"
3. define a custom SKILL function e.g. openPDF(fileName) to open fileName using the PDF viewer specified according to the value of an external PDF_VIEWER environment variable if set, use a default value otherwise. Question: do exist in Cadence IC a SKILL routine to open a PDF file? I know that Cadence Allegro provides an axlPdfView(fileName) function for this task, as discussed in
community.cadence.com/.../11357
but I can't find an equivalent counterpart for the Cadence full-custom design environment.
4. loop over PDF files and recursively use the hiCreateMenuItem() function to dynamically create menu items and callbacks to the openPDF function. When I mention "dynamically" I'm referring to the fact that I want to use just one for/foreach loop over PDF_DOCLIST and LABELS_DOCLIST items, so I can add further menu entries just by adding new items to PDF_DOCLIST and LABELS_DOCLIST lists
5. complete the menu creation using hiCreatePulldownMenu() and  hiInsertBannerMenu()
Up to now I wrote the following code:
ciwMenuInit()
PDF_DOCLIST = list("/path/to/fileName1.pdf" "/path/to/fileName2.pdf" "etc.")
LABEL_DOCLIST = list("Meaningful text label for fileName1.pdf" "Meaningful text label for fileName2.pdf" "etc.")
;; select the PDF viewer
if( getShellEnvVar("PDF_VIEWER") != nil  && isFile(getShellEnvVar("PDF_VIEWER") )
then
   PDF_VIEWER = getShellEnvVar("PDF_VIEWER")
else
   PDF_VIEWER = "/usr/bin/xpdf"
) ;; if
;; loop over PDF_DOCLIST items to add pull-down menu entries
index = 0
menu_entries = list()
foreach(fileName PDF_DOCLIST
   menu_entries = cons(
      hiCreateMenuItem(
         ?name       gensym('fileName)
         ?itemText   nth(index LABEL_DOCLIST)
         ?callback   "openPDF(fileName)"
      ) ;; hiCreateMenuItem
   menu_entries
   ) ;; cons
   index = index + 1
) ;; foreach
;; Define a new custom SKILL function to display the PDF
procedure(
   openPDF(fName)
      printf("Opening PDF document %s \n" fName)
      csh(strcat(PDF_VIEWER " " fName "&") )
) ;; procedure
;;  Create the new pull-down menu and populate it with previously-defined entries (I don't show here the technology Xyz I'm working with)
NewXyzMenu = hiCreatePulldownMenu(
   'NewXyzMenu
   "Open Xyz Documentation"
   menu_entries
) ;; hiCreatePulldownMenu
;; Insert the menu before the default Help entry in the CIW
hiInsertBannerMenu(
   window(1)
   NewXyzMenu
   99
) ;; hiInsertBannerMenu
With this code I've succesfully added the pull-down menu in the Virtuoso CIW and all document names listed in LABEL_DOCLIST appear, but when I try to left-click on any items in the menu the call to the openPDF fails with the following error:
*Error* eval: unbound variable - fileName
I think that the iterator fileName of the foreach loop is considered as a local variable, hence for some reason its value is not seen within the hiCreateMenuItem() function when I specify the ?callback entry. This is strange since the same variable is seen by the gensym() function that creates a symbol for ?name. Interesting if I add an auxiliary global variable in the foreach loop e.g.
   fileName_global = fileName
      hiCreateMenuItem(
         ?callback   "openPDF(fileName_global)"
   menu_entries
   ) ;; cons
   index = index + 1
) ;; foreach
when I left click on any menu items it turns out that the call to openPDF function ALWAYS DISPLAYS THE SAME PDF FILE for all entries defined in PDF_DOCLIST !
Certainly something is wrong, maybe in the definition of the openPDF() function or in the iterated assignments to ?callback in the hiCreateMenuItem() function? Actually I tried to use let() and declare local variables too, but nothing changes.
I wrote a similar script to add the same feature in Cadence Encounter Digital Implementation System using Tcl and everything works fine:
uiAdd XyzMenu -type menu  -label "Xyz PDK"  -in main
uiAdd XyzDocMenu  -type submenu -label "Open Xyz Documentation" -in XyzMenu
set PDF_DOCLIST [list "/path/to/fileName1.pdf" /path/to/fileName2.pdf" "etc"]
set LABEL_DOCLIST [list "Meaningful text label for fileName1.pdf" "Meaningful text label for fileName2.pdf" "etc."]
set PDF_VIEWER /usr/bin/xpdf
for {set i 0} {$i < [llength $PDF_DOCLIST]} {incr i} {
   uiAdd DesignRulesDoc  -type  command                               \
                                     -in    XyzDocMenu                              \
                                     -label [lindex $LABEL_DOCLIST $i]     \
                                    -command "exec $PDF_VIEWER [lindex $PDF_DOCLIST $i] &"
Thanks in advance for hints and suggestions!
Cheers
Luca
OS: RHEL 6.6 64-bit
Cadence IC version: IC6.1.6
Cadence EDI version: 14.13
  • theopaone
    theopaone over 11 years ago
    With this line, your are passing in the symbol fileName rather than a value. This is the source of your error.
    Change this line to
    ?callback sprintf(nil "openPDK(%s)" fileName)
    This will insert the value of fileName into the string for the command.
  • Pacher Luca
    Hi theopaone,
    You are definetely right and now with your suggestion all PDF files can be properly accessed from my new CIW pull-down menu! Actually in order to make the code working I needed to add a couple of escaped double-quotes,
    ?callback sprintf(nil "openPDF( \"%s\" )" fileName)
    Now I'm happy  :-)
    Many thanks for your replay!
    Luca
