  3. Issue facing in working with concatenated list
  • Subscribers 150
  • Views 14432
varun kumar D
varun kumar D over 11 years ago
procedure(c()
cv=geGetEditCellView()
TT=nil
foreach(tan cv~>instances
foreach(tan1 tan~>prop~>name
          if(member(tan1 list("PAD"))
                     then
         b=list(tan)
        TT=append1(b TT)
printf("%L", tan)
for(i 0 1
mm=nth(i TT)
if(nth(i TT)
;printf("%L", mm)
println("hh")
foreach(prop2 mm~>prop
        foreach(prop1 list(prop2 )
        if( rexMatchp("vddcore3v" prop1~>name) == t  then
        rexCompile("!")
        nmOfLbl = rexReplace(prop1~>value "" 0)
        padLabel = append1(padLabel list(prop1~>name nmOfLbl))
problem:   Just FYI
TT= (db:0x1879a313    (db:0x1879a312 nil))
I want to work on one dbid at a time. but second dbid is having 2 element which is creating issue.
but after nth command nth (0 TT) is taking first element out but in second element  is combination of two ((db:0x1879a312 nil)) .
Pls let me how to work on one element at a time if its a concatenated list.
  • theopaone
    theopaone over 11 years ago
    TT=append1(b TT) is your problem. Your use of append1 appends the complete TT list to b. Try: TT = append(TT b) or use cons to put b on the front of the list (get rid of the b=list(b)) => TT = cons( b TT)
