  3. repeated element in the list how to remove ? (issue facing...
  • Views 15249
repeated element in the list how to remove ? (issue facing in code list having the same element)
varun kumar D
varun kumar D over 11 years ago
I have below list in which I want to remove the repeated list.
Input:
(("gndcore" "P15_VSS3V3")
("vddcore3v3" "P16_VDDI3V3")
("vddcore1v" "vddcore1v0")
("gndcore" "P33")
desired output:
("gndcore" "P33")
  • skillUser
    skillUser over 11 years ago
    Hi Varun,
    If order does not matter then you could use this procedure (rewritten from one that Tom Weeks provided a while ago):
    procedure(CCFremoveDupesFromList(inputList "l")
      let( ((table makeTable("CCFdupTable" nil)) )
        foreach(element inputList
          table[element] = t
        table->?
      ); let
    ); procedure
    Call the procedure on your list and get back a version with duplicates removed, for example:
    CCFremoveDupesFromList(list(1 2 1 1 3 4 5))
      => (5 4 3 2 1)
    CCFremoveDupesFromList('(("gndcore" "P15_VSS3V3") ("vddcore3v3" "P16_VDDI3V3")
      ("vddcore1v" "vddcore1v0") ("gndcore" "P33") ("gndcore" "P15_VSS3V3")
      ("vddcore3v3" "P16_VDDI3V3"))
    => (("vddcore3v3" "P16_VDDI3V3")
        ("gndcore" "P33")
    Hopefully this is what you were looking for? If not, try searching this forum with keywords like "remove duplicate list", it's how I found the above example.
    Best regards,
    Lawrence.
