  3. Add angle brackets to layout instance name
  • Views 15235
LongTimeNovice
LongTimeNovice over 11 years ago
Hello.  I'm trying to rename some layout instances, and I want to use angle brackets in the new names.  The following code works well as long as I don't try to use angle brackets.  If I do try to use angle brackets, I get this response:
*WARNING* (DB-270169): dbSetAnyInstBaseName: expecting a scalar name for the baseName -- Autogen<1>
*WARNING* (DB-270169): dbSetAnyInstBaseName: expecting a scalar name for the baseName -- Autogen<2>
Here is the code:
(procedure renameLayoutInst()
let((cv cnt instList)
cv=geGetWindowCellView()
instList=selectedSet()
labelLayer = list("text" "drawing")
cnt = 0; initialize CNT
foreach(inst instList
newInstName=strcat("Autogen<" pcExprToString(cnt++) ">")
while( dbFindAnyInstByName(cv newInstName)
);; while
inst~>baseName=newInstName
) ;foreach
) ;let
) ;procedure
What am I missing?
Thank you!
Steven.
  • LongTimeNovice
    Nevermind. Sometimes it just helps to walk away for a bit. I just realized I should be using () instead of <> for the instance names, and it works great. Thanks.
