  3. Get database IDs for items in a flattened mosaic
  • Subscribers 150
  • Views 15361
LongTimeNovice
LongTimeNovice over 11 years ago
Hello, all.
Is it possible to get the database IDs for all the items in a mosaic that I just flattened?  So if a mosaic had 6 instances, I would want the IDs for those 6 after I flatten the mosaic.  I should say that my ultimate goal is to select those 6 instances, and I assume the way to do that is to determine their IDs and then select by ID, but if that's not the correct way, or if there's a better way, please let me know.
Thank you very much!
Steven.
  • theopaone
    theopaone over 11 years ago
    Not an easy task as the dbFlattenInst only returns t or nil. You could do the following:
    Find the instance header for the mosaic and cache all the instances before flattening.
    mosaicIH = mosaicId~>instHeader
    curInstances = mosaicIH~>instances
    After the flattening (only flatten one level), the new instances are added to the instance header.
    newInstances = setof( inst mosaicIH~>instances !(member inst curInstances))
    You may be able to use memq instead of member for higher performance.
  • LongTimeNovice
    theopaone!  That's exactly what I needed.  I've been struggling for days with this.  Thank you!
