  3. How to convert PATH into POLYGON with using program or tools...
  • Replies 7
  • Views 21595
How to convert PATH into POLYGON with using program or tools of VIRTUOSO
mochio
mochio over 11 years ago
Hi ,
I would like to know how to convert PATH into POLYGON with using program or tools of VIRTUOSO.
Would you tell me tha method?
I am a begginer of using VIRTUOSO.
  • psill000
    psill000 over 11 years ago
    Have you tried the skill function
    leConvertShapeToPolygon(
    d_shapeId
    [ x_sides ]
         => d_polygonId / nil
  • mochio
    Hi,Psill000
    Thank you for your help.
    Sorry for my late response.
    Where do I have to discribe following Skill code in VIRTUOSO ?
    Do I have to type Skill code in CIW ?
     I am a beginner  of using VIERTUOSO.
     I would like to tell me about it  when you have  time.
    d_shapeId
    [ x_sides ]
  • theopaone
    theopaone over 11 years ago
    The very basic way is to create a file with a .il extension and define a procedure in it. Do this in a text editor. The SKILL Language User guide will guide you.
    procedure( myFlattenToPolygon()
     foreach( shape selectedSet() leConvertShapeToPolygon(shape))
    load the file and type in the procedure name to execute it.
    There are plenty of examples in the SKILL documents.
    You might think about taking some programming training or even attending a SKILL class. I don't know if the class is available on line but is well worth the time you put in.
    Or if you don't want SKILL code (Since you seem to know nothing about SKILL), then just use Edit->Convert->To Polygon in the  layout editor.
  • mochio
    Hi theopaone
    Sorry for very late response and thank you for your reply.
    Finally I found the Skill Language User guide in my office.
    I am reading it.
  • mochio
    Hi Andrew
    Thank you for your advice.
    I would like to convert all extracted PATH with Virtuoso skill to POLYGON by 1 operation .
    I found Virtuoso Skill manual in my office today.
    I will read it.
    mochio mochi said:
    Hi Andrew
    Did you have a question?
