  3. Need help with leMakeCell
  • Subscribers 150
  • Views 14962
LongTimeNovice
LongTimeNovice over 11 years ago
Clearly I'm a novice.  This is a basic question that I should be able to figure out myself, but I'm having no luck.
My script selects some instances.  Then I run this code:
instList=selectedSet()
leMakeCell( list(instList) "test_library" "newCellName" "layout" t )
and I get this error:
Error* lefMakeCell: Invalid figure - (db:0x05d42db1 db:0x05d42db2 db:0x05d42db3 db:0x05d42db4 db:0x05d42d9c ... )
What am I doing wrong?  Isn't that a valid list of database IDs to make a cell from?
Thank you!
  • theopaone
    theopaone over 11 years ago
    instList is already a list, try: leMakeCell( instList "test_library" ...)
  • LongTimeNovice
    Yes, perfect. The easy answer that I didn't see! Thank you, theopaone!
