  3. changing layers in skill???
  • Views 16927
archive over 19 years ago
I'm trying to change the layer (tx_layer) of a db object with skill.  For example, let's say I have an object that is simply a rectangle of M1.  Is there a way to change that object to be the same size rect, but of M1?  I'm looking through the documentation, but I don't see any functions that allow you do to this.
Originally posted in cdnusers.org by clafrieda
    Ah, I figured it out.
    dbSet(cvid "M2" "layerName")
    Presumably cvid in your case was not a CellView Id (as the variable name suggests) but the db object representing the shape you want to modify?
    If so, you could have done this with:
    shape~>layerName="M2"
    which is the same as doing:
    dbSetq(shape "M2" layerName)
    Using dbSet allows the attribute name (the third argument) to be an expression - in this case the string is converted to a symbol automatically.
    Originally posted in cdnusers.org by adbeckett
    If you like to do this interactive too, when working on selected objects, you could
    define bindkeys to change the layers of selected objects. I use this regularly to
    change the layer from one metal to another or to poly. With Shift-Alt-1 to M1, Shift-Alt-2 to
    M2 etc. Works on single or multiple selected paths or polygons. I also use it
    when creating layouts to follow paths by changing one selected path deliberately
    to another layer (and don't forget to change it back!) to easily follow it accross
    the design.
    If you want you can look at my bindkeys at:
    http://relyveld.wordpress.com/ - Relyveld's blog - cadence page
    Greetings, William.
    Originally posted in cdnusers.org by relyveld
