  3. dialog interactive window noise summary
  • Subscribers 150
  • Views 15514
archive over 19 years ago
Dear all,
Howto pop up a window and take a string into a variable in SKILL ?
I intend to upgrade my "print noise summary" button listed bellow in order to save it in the choosen file, like : scanf("%s",filename) or something.
Thanks for any idea.
;; A noise simulation is supposed to have been run
procedure( saveNoise( filename )
noiseSummary( 'integrated ?result 'noise
?noiseUnit "V"
?truncateType 'byNumber ?truncateData 15
?output filename)
printf("Noise Summary Result saved in %s\n",filename)
); end procedure
;; i.e.: saveNoise( "toto.txt")
;;; creating a item for the pulldown menu
trMenuItemMyFunction = hiCreateMenuItem(
?name 'trMenuItemMyFunction
?itemText "My Function"
?callback "saveNoise(\"summaryNoise.txt\")"
); end of created Menu item
;;; creating a second menu item for the pulldown menu
trMenuItemPrintNoiseSummary = hiCreateMenuItem(
?name 'trMenuItemPrintNoiseSummary
?itemText "print noise"
?callback "noiseSummary( 'integrated ?result 'noise ?noiseUnit \"V\" ?truncateType 'byNumber ?truncateData 15)"
;;; creating the Example Menu pulldown menu
hiCreatePulldownMenu(
'trEdPulldownMenu
"Ed_Menu"
list( trMenuItemMyFunction trMenuItemPrintNoiseSummary )
;;; inserting the pulldown menu in the CIW
hiInsertBannerMenu( window(1) trEdPulldownMenu 5 )
Originally posted in cdnusers.org by ebecheto
    I have update this code to work for paramatric simulation as well if anyone is interested...
    Just save the following code in thisFile.ocn and execute :
    load("thisFile.ocn")
    procedure( noiseResult( @optional (file nil ) )
    let( (resultDir pfile param paramList)
    ;; optional argument proccessing
    caseq( file
    (nil pfile = poport)
    (t pfile = outfile(file))
    ;; execute the following code
    ;; does not work if anyone had created a directory named *=* also
    if( paramList=rexMatchList(".*=.*" ls(openResults())) then
    ;; loop on every paramatric directory
    resultDir = openResults()
    foreach(param paramList
    openResults(strcat(resultDir "/" param))
    fprintf(pfile "\t\t[** %s **]\n",param)
    noiseSummary( 'integrated ?result 'noise ?noiseUnit "V" ?truncateType 'byNumber ?truncateData 15 ?output pfile)
    ); end foreach
    openResults(resultDir)
    else ;; not a parametric simulation
    ;; call to the noise summary function in the current directory
    ); end if
    close(pfile)
    ); end let
    ); end procedure
    ?itemText "Save noise"
    ?callback "filename = \"summaryNoise.txt\"
    noiseResult( filename )
    printf(\"Noise Summary Result saved in [_** %s/%s **_]\n\", pwd() filename)"
    ?callback "noiseResult()"
    ;; noiseSummary( 'integrated ?result 'noise ?noiseUnit "V" ?truncateType 'byNumber ?truncateData 15)
    ;;; creating the menu item for the pulldown menu
    trMenuItemResize = hiCreateMenuItem(
    ?name 'trMenuItemResize
    ?itemText "Resize"
    ?callback "hiResizeWindow( window(1) list(0:0 500:500))"
    'trEdPulldownMenu
    "Menu_perso"
    list( trMenuItemMyFunction trMenuItemPrintNoiseSummary trMenuItemResize)
    ;; might want to delete it maybe
    ;;hiDeleteBannerMenu( window(1) 5 ) <== number of the item
