  3. problems about create form
  • Views 16209
nidon2003
nidon2003 over 11 years ago
Hi everyone,
I write a script to create forms as follow:
procedure(testCallback(name)
let(()
fieldName=concat(name)
testStringField=hiCreateLabel(
?name fieldName
?labelText strcat("This is test form from " name) )
filedForm = hiCreateAppForm(
?name fieldName
?formTitle "test"
?buttonLayout 'OKCancel
?fields
list(
list(testStringField 0:20 200:40)
hiDisplayForm(filedForm 650:250)
procedure(FormTest()
let(()
itemList=nil
hButton=40
yButton=20
for(i 1 10
itemName=concat("test" sprintf(nil "%n" i))
itemText=strcat("test" sprintf(nil "%n" i))
itemCallback=sprintf(nil "testCallback(%L)" itemText)
item=list(
hiCreateFormButton(
?name itemName
?buttonText itemText
?callback itemCallback)
0:yButton+40*(i-1)
410:hButton )
itemList=cons(item itemList)
FormTest = hiCreateAppForm(
?name 'FormTest
?formTitle "Form Test"
?fields itemList )
) ;let
FormTest()
hiDisplayForm(FormTest 350:250)
But  it shows two warnings when i run it,
Warning hiDeleteForm: Cannot delete a form that is mapped or form within the form's callback
Warning hiCreateForm: Could not delete already created form.
I can't to solve these warnings, please give me some help.
Thank you very much!
    The code works fine - I tried it.
    The warnings you are seeing only occur if a form that is being recreated (or attempted to be recreated) is already displayed on the screen at the time you recreate it. You need to OK or cancel the form first before recreating it.
  • skillUser
    skillUser over 11 years ago
    Your code has 'let()' statements with no declarations and thus there are no local variables, they all become global.  I've modified the code a little so that it will pass SKILL Lint with a score of 100.
      let((fieldName testStringField filedForm)
      fieldName=stringp(name) && concat(name) || name
        ?name fieldName
        ?name fieldName
        ?formTitle "test"
        ?fields list(
      ); let
    ); procedure testCallback
      let((item itemList (hButton 40) (yButton 20))
        for(i 1 10
          item=list(
            hiCreateFormButton(
              ?name         concat('test i)
              ?buttonText   sprintf(nil "Test %n" i)
              ?callback     sprintf(nil "testCallback(\"test%n\")" i)
            0:yButton+35*(i-1)
            410:hButton
        ); for
        ;; creates and returns global form variable/structure FormTest
        hiCreateAppForm(
          ?name 'FormTest
          ?fields itemList
      ); let
    ); procedure FormTest
    You can use it in the same way as before, or more simply: hiDisplayForm(FormTest() 350:250)
    Lawrence.
  • nidon2003
    Thanks for you reply,  Andrew and Lawrence
       As you said above, i found the problem in my code and got a way to solve it. In the new code, if the test form has been created, it will not be recreated again. The whole code as follow:
    let((fieldName testStringField filedForm )
    ?name fieldName
    ?name fieldName
    ?formTitle "test"
    ?fields
    list(
    ;; hiDisplayForm(filedForm 650:250)
    procedure(test1(name)
    let((fieldName)
    unless(boundp(fieldName) testCallback(name) )
    let((itemList hButton yButton itemName itemText itemCallback item)
    itemList=nil
    hButton=40
    yButton=20
    for(i 1 10
    itemCallback=sprintf(nil "test1(%L)" itemText)
    item=list(
    hiCreateFormButton(
    ?name itemName
    0:yButton+40*(i-1)
    410:hButton )
    ?name 'FormTest
    ?fields itemList )
    ) ;let
    FormTest()
