  3. Creating aligned array of diffusion contacts
  • Subscribers 150
  • Views 17723
ssarik
ssarik over 11 years ago
I am a new SKILL user. As a start point I am trying to make an inverter using ROD.
For diffcons I have created an array of diffcons using rodCreateObj, but when I am trying to align it is giving a warning that it is not a valid ROD object.
Below is the skill code which I have written.
procedure( TrCreateInverterROD2(libName)
   ;-- Create a new layout cellview for the inverter
   newCV = dbOpenCellViewByType(libName "inverterROD2" "layout" "maskLayout" "w") ;;; New layout cell view for the inverter
   invWid = geOpen(?lib libName ?cell "inverterROD2" ?view "layout") ;;; Opening the layout window
   ;-- Delete any object present in the cellview
            geSelectAll() ;;; Select all the objects in the design
            foreach( dbObject geGetSelSet()
                              dbDeleteObject( dbObject)
                   )   ;;; Loop through each of the object and delete them
            ;-- Create required shapes for inveretr in ROD format
   nwell   = rodCreateRect( ?cvId newCV ?name "nwell" ?layer "nwell" ?width 3.4 ?length 3.4 )
   poly    = rodCreateRect( ?cvId newCV ?name "poly" ?layer "poly" ?width 0.4 ?length 5.2   )
   pdiff1  = rodCreateRect( ?cvId newCV ?name "pdiff1" ?layer "pdiff" ?width 1 ?length 2.4  )
            pdiff2  = rodCreateRect( ?cvId newCV ?name "pdiff2" ?layer "pdiff" ?width 1 ?length 2.4  )
            ndiff1  = rodCreateRect( ?cvId newCV ?name "ndiff1" ?layer "ndiff" ?width 1 ?length 1.4  )
            ndiff2  = rodCreateRect( ?cvId newCV ?name "ndiff2" ?layer "ndiff" ?width 1 ?length 1.4  )
            metal0  = rodCreateRect( ?cvId newCV ?name "metal0" ?layer "metal0" ?width 0.4 ?length 0.4 )
            metal1  = rodCreateRect( ?cvId newCV ?name "metal1" ?layer "metal1" ?width 0.5 ?length 2.03 )
            metal2  = rodCreateRect( ?cvId newCV ?name "metal2" ?layer "metal1" ?width 0.5 ?length 1.305)
            metal3  = rodCreateRect( ?cvId newCV ?name "metal3" ?layer "metal1" ?width 0.5 ?length 4.567)
            arrayOfDiffCon0  = rodCreateRect( ?cvId newCV ?name "arrayOfDiffCon0" ?layer "diffcon" ?width 0.5 ?length 0.5
            ?elementsX 1 ?elementsY 3 ?spaceY 0.225 )
            arrayOfDiffCon1  = rodCreateRect( ?cvId newCV ?name "arrayOfDiffCon1" ?layer "diffcon" ?width 0.5 ?length 0.5
            ?elementsX 1 ?elementsY 3 ?spaceX 0.225)
   arrayOfDiffCon2  = rodCreateRect( ?cvId newCV ?name "arrayOfDiffCon2" ?layer "diffcon" ?width 0.5 ?length 0.5
            ?elementsX 1 ?elementsY 2 ?spaceX 0.225 )
            arrayOfDiffCon3  = rodCreateRect( ?cvId newCV ?name "arrayOfDiffCon3" ?layer "diffcon" ?width 0.5 ?length 0.5
   viag = rodCreateRect( ?cvId newCV ?name "viag" ?layer "viag" ?width 0.4 ?length 0.4 )
            chkBoundary = rodCreateRect( ?cvId newCV ?name "chkBoundary" ?layer (list "chkBoundary" "boundary") ?width 3.4 ?length 5.8)
   ;--- Align the nwell and poly
   rodAlign( ?alignObj    poly
       ?alignHandle "upperLeft"
                      ?refObj      nwell
                      ?refHandle   "upperLeft"
                      ?xSep        1.5
       ?ySep        -0.3
   ;--- Align the pdffis
   rodAlign( ?alignObj    pdiff2
                      ?refObj      pdiff1
                      ?refHandle   "upperRight"
                      ?xSep        0.4
       ?ySep        0
            ;--- Align the ndiffs
            rodAlign( ?alignObj    ndiff2
                      ?refObj      ndiff1
                      ?xSep        0.4
       ?ySep        0
            ;--- Align poly and pdiff
                      ?refObj      pdiff1
                      ?ySep        0.2
                      ?xSep     0
   ;--- Align pdiff and ndiff
   rodAlign( ?alignObj    pdiff1
       ?alignHandle "lowerLeft"
                      ?refObj      ndiff1
                      ?ySep        1
                      ?xSep     0
            ;--- Align output metal line
   rodAlign( ?alignObj    metal3
       ?alignHandle "upperRight"
                      ?refObj      pdiff2
                      ?ySep        -0.185
                      ?xSep     -0.25
   ;--- Align source drain metal contacts
   rodAlign( ?alignObj    metal1
                      ?refObj      pdiff1
                      ?ySep        -0.185
                      ?xSep     0.25
            rodAlign( ?alignObj    metal2
                      ?refObj      ndiff1
                      ?ySep        -0.047
                      ?xSep     0.25
            ;--- Creating gate connection
   rodAlign( ?alignObj    viag
                      ?alignHandle "lowerCenter"
                      ?refObj      poly
                      ?refHandle   "lowerCenter"
                      ?ySep        1.9
   rodAlign( ?alignObj    metal0
                      ?alignHandle "centerCenter"
                      ?refObj      viag
                      ?refHandle   "centerCenter"
   ;--- Creating diffusion connection
      rodAlign( ?alignObj   arrayOfDiffCon0
                      ?refObj         metal3
                      ?refHandle   "lowerLeft"
                      ?ySep        2.4
                      ?xSep     0
   ;--- Align the check boundry
   rodAlign( ?alignObj    chkBoundary
                      ?refPoint 0:0
   ;--- Align nwell with check boundry
   rodAlign( ?alignObj    nwell
                      ?refObj      chkBoundary
                      ?ySep        2.4
                      ?xSep     0
   dbSave(newCV)
   printf("Done\n")
    This is because arrayOfDiffCon0 etc contains a list of rod objects - one per rectangle that was created. You can't align (or align to) a list of rod objects - you have to align to a handle of an individual rod object. So you'll need to either create a multi-part rectangle and align that, or align the individual rectangles in the list.
  • ssarik
    Thanks for the reply.
    I changed the diffcon code to the following
          rodAlign( ?alignObj   arrayOfDiffCon0.1
                          ?refObj         metal3
                          ?ySep        2.4
                          ?xSep     0
    Now I am getting an error stating that there is a syntax error at arrayOfDiffCon0.1
    Shahbaz
    You either need to pass one of the members of the list (e..g car(arrayOfDiffCon0) ) or a rod object - here you're just passing a variable name - and that's an illegal variable name (with a dot in). Maybe you want to use:
    ?alignObj rodGetObj("arrayOfDiffCon0.1" newCV)
  • theopaone
    theopaone over 11 years ago
    This is not valid SKILL syntax: arrayOfDiffCon0.1
    To access a member of a list in SKILL, you can use
    the positional functions (nth or nthelem) - nth(arrayOfDiffCont0)
    the faster ones based on the lisp pointers such as car, cadr, cadar, etc. - car(arrayOfDiffCont0)
    find the ROD object in the database like Andrew's example. - rodGetObj("arrayOfDiffCon0.1" newCV)
    The second one is the fastest.
    Ted
