  3. Doubt in IPC
  • Views 14527
Doubt in IPC
Manikk0501
Manikk0501 over 11 years ago
Hi all,
I am running a perl script through IPC from SKILL environment. My perl process will launch the log file using nedit. But the process execution is not switching back to SKILL environment till I close the nedit even after the perl process is over. I tried with nedit <logifle> & also. It did not work.
Can anyone help me on this?
Thanks and Regards,
Manikandan Kuzandhaivelu
    Hi Manikandan,
    As I said to you in the direct email conversation - there's not enough information here to be able to debug what your problem is.
    Showing the code would be a good idea.
