  3. Comparison of the formated list and print in the specific...
  • Views 14679
Comparison of the formated list and print in the specific format
varun kumar D
varun kumar D over 11 years ago
hello,
I have the list  given below in this format  , which is saved in the variable BigList . In this list only first few string are  unmatched  and rest strings are  the same  .  I want to create new Biglist in which repeat element should removed and the  unmatched component  in the list  should be present in the new biglist.
BigList=
("P2_JTAGTE" "route_I644" "I689" "P10_IN" "P14_OUT"
"P19_IN" "P18_IN" "P20_OUT" "P17_IN" "I671"
"I670" "route_I615" "I669" "route_I616" "P13_IN"
"P12_OUT" "P11_IN" "I668" "route_I518" "I672"
"route_I519" "P1_JTAGCLK" "P3_JTAGTDI" "P4_JTAGOUT" "P15_IN"
"P23_IN" "P24_OUT" "P62_OUT" "P61_OUT" "P63_OUT"
"P64_OUT" "route_I632" "P8_INOUT" "P7_OUT" "P9_OUT"
"route_I641" "I743" "I687"
("P4_JTAGOUT" "P15_IN" "route_I644" "I689" "P10_IN"
"P14_OUT" "P19_IN" "P18_IN" "P20_OUT" "P17_IN"
"I671" "I670" "route_I615" "I669" "route_I616"
"P13_IN" "P12_OUT" "P11_IN" "I668" "route_I518"
"I672" "route_I519" "P1_JTAGCLK" "P3_JTAGTDI" "P2_JTAGTE"
("P15_IN" "P4_JTAGOUT" "route_I644" "I689" "P10_IN"
("P23_IN" "P13_IN" "P12_OUT" "P11_IN" "route_I644"
"I689" "P10_IN" "P14_OUT" "P19_IN" "P18_IN"
"P20_OUT" "P17_IN" "I671" "I670" "route_I615"
"I669" "route_I616" "I668" "route_I518" "I672"
"route_I519" "P1_JTAGCLK" "P3_JTAGTDI" "P2_JTAGTE" "P4_JTAGOUT"
"P15_IN" "P24_OUT" "P62_OUT" "P61_OUT" "P63_OUT"
Intended Output:
("P2_JTAGTE" "P4_JTAGOUT" "P15_IN",P23_IN" "P13_IN" "P12_OUT" "P11_IN, "route_I644" "I689" "P10_IN" "P14_OUT"
    Again, this is really unclear. I don't know what you're talking about by "first few strings are unmatched and rest strings are the same". Or "unmatched component". If you are talking about taking a list of lists of strings and producing a list of the unique strings across the sub-lists, then it would be something like this:
    procedure(CCFwildGuess(listOfLists)
      let(((unique makeTable('unique nil)))
        foreach(outer listOfLists
            foreach(inner outer
                unique[inner]=t
        unique->?
    CCFwildGuess(bigList)
    which produces:
    ("P2_JTAGTE" "P7_OUT" "P15_IN" "P20_OUT" "P63_OUT"
        "I687" "route_I519" "P12_OUT" "P14_OUT" "P61_OUT"
        "I689" "P10_IN" "route_I641" "P1_JTAGCLK" "route_I615"
        "P18_IN" "P4_JTAGOUT" "I668" "route_I518" "P11_IN"
        "route_I644" "P8_INOUT" "P13_IN" "P17_IN" "P3_JTAGTDI"
        "I671" "P62_OUT" "route_I616" "P23_IN" "route_I632"
        "I672" "I669" "P24_OUT" "P64_OUT" "I743"
        "I670" "P19_IN" "P9_OUT"
    I made no attempt to keep these in any specific order (they are just in "hash" order) - because your question was so unclear I don't know if I've understood you correctly. Your example output has some repeated names in it - so it's hard to know what you really wanted. These were repeated in your output list:
    "P13_IN"
    "P12_OUT"
    "P11_IN"
    "P4_JTAGOUT"
    "P15_IN"
    "P23_IN"
