  3. Tracing the nets in a schematic when net is part of a bus...
  • Views 16071
Tracing the nets in a schematic when net is part of a bus or a terminal into an array of instances
santoshkjoshi
santoshkjoshi over 11 years ago
I am trying to write a script which can trace a net hierarchically. I went through lot of post and got it working for a simple setup. Most useful post was this one. It describes most of the steps and I was able to get to a good point. I am following the functions in the post. I am running the script using dbAccess as it is being invoked from shell.
The problem arises when a net (let say "A", originating from one of the terminals of an instance) is going as a part of bus(Signal "B<2>" in bus B<3:0>") to another instance. In this case,
conns = setof(x net~>instTerms neq(x instTerm))
is not returning the connections to the signal in the bus in conns variable. What property of net contains the information of connection to a bus type terminals of another instance?
In this same context, some times when I try to find an instance by name using dbFindAnyInstByName, I am not able to open specific instance from the array. For example, if we have an instance Ickt<2:0> and I want to open instance Ickt<2>, which function should be used in this case.
I am using Virtuoso ICAD12.1, in case it helps.
In case, these 2 questions are not interrelated, I will move the later one to other post.
Santosh
  • santoshkjoshi
    I might look impatient here. But just asking for asking more info if required
    If more information is required for anyone try to answer this, please let me know. It will also be good to know ahead, in case the route I am trying itself is wrong.
    Best Regards,
    Santosh
