  3. SKILL code for ocean script for implementing modulus function...
  • Views 18983
SKILL code for ocean script for implementing modulus function involving floating point numbers
deelal
deelal over 11 years ago
I am trying to write an ocean script using SKILL code to run some simulations in Cadence.
Specifically, to determine the magnitude of aliased harmonics in a sampling system, I am trying to use the modulus function.
How can I implement something like 10%3.1 in SKILL? The mod function only allows for use of integers (e.g. mod(10,3) gives 1), however I have a set of numbers (frequencies) that are floating point.
Any helps/hints would be appreciated.
    modf() is the function you're looking for.
  • deelal
    Thank you, is there a manual or a document where I can find this function? The latest version I have for the SKILL reference is from 2003.
    Thanks for your help.
    Regards
    Deeksha
  • skillUser
    skillUser over 11 years ago
    Hi Deeksha,
    If you have access to Cadence online support then you can access all of the documentation, here's a link for the modf() function.
    Hopefully this helps?
    Lawrence.
    The documentation is also in every installation - so in <ICinstDir>/doc/sklangref/sklangref.pdf .
    The modf() function was added in IC616, I believe. However, it's trivial to write your own:
    procedure(CCFmodf(a b)
      a-b*round(a/b)
  • deelal
    Yes this helps, thanks Lawrence. I'm still new to the website, and wasn't sure where to look.
  • deelal
    Thanks Andrew. I was able to write my own code but I was hoping (as Lawrence pointed out) that there would be an updated reference manual somewhere.
