  3. Hyperlink text links to to instances or nets using Skil...
  • Views 16112
Hyperlink text links to to instances or nets using Skill
VenuA
VenuA over 11 years ago
I want to dump a log file that has instance names with clickable links (similar to LVS Error/Compare report) that will highlight instances and nets.
Can you please let me know how I can generate a HTML +Skill call logfile?
Venu
  • dmay
    dmay over 10 years ago
    Take a look at this post:
    http://community.cadence.com/cadence_technology_forums/f/48/p/28984/1334421#1334421
    The trick is to include the necessary information in your hypertext link so that the callback can do what you want it to do. In the example, the hypertext link has some coordinates and the callback zooms to those coordinates. In your case, you need instance names and net names in the hypertext and a callback that knows what to do with them.
    Derek
  • VenuA
    VenuA over 10 years ago
    Thanks. I will be testing out these examples.
