  3. Reading a list of columns
  • Views 15404
ADITYA VOORA
ADITYA VOORA over 11 years ago
i want a skill program for reading a list of columns
if it is two columns it want to show error
if it is one column it want give true
this should be happen in entire list
    Your question is rather imprecise. For example:
    1. Where is it reading this list of columns from? Is it a file? Is it an existing list?
    2. What defines a "column" - i.e. what is the separator, what kind of data are you expecting in each column? Numbers? Words?
    3. Do you really want to read the list of columns and discard what you read so that it returns true or false?
    If you don't ask a clear question, then you won't get a clear answer...
  • ADITYA VOORA
    for example:     a list has a set of names  like as follows
    list (cell1 cell2)
    In this list it want find second column
    But i required only column
    so code want to show error
    Your question is still very poorly framed. So let me give some assumptions and a possible solution. If you have two lists:
    good=list(
      list("cell1")
      list("cell2")
      list("cell3")
    bad=list(
      list("cell1")
      list("cell2" "info2")
      list("cell3" "info3")
    then you could do:
    data=bad ; or data=good
    when(exists(row data cdr(row))
      error("more than one column")
  • ADITYA VOORA
    Actually i'm in starting of learning SKILL that's why my questions is like that
    Thank You for answering me.
    This is sufficient for know if i have any doubts i will post here.
    Thank You Once again
