  3. Variation in output amplitude calculated by DFT() for an...
  • Views 14538
Variation in output amplitude calculated by DFT() for an ideal sine voltage source
deelal
deelal over 10 years ago
Summary of problem:
I'm working on calculating the dft of some signals in Cadence. If I plot the DFT of a signal, say from 1GHz to 9GHz, for the same input amplitude over all frequencies, I get a DFT magnitude that varies greatly (-6dBm at 1GHz, -40dBm at 5GHz etc.).  For the same number of sampled points, same input amplitude, I would expect the same output magnitude over the entire frequency range.
My test circuit: An ideal vsin component from analogLib (frequency FIN, amplitude AmpIN) in series with a resistor, R1.
Methodology: In order to calculate the DFT of the output, here's what I do:
1. Use a 2^n number of FFT sampled points (npts).
2. Set a sampling frequency (FS)
3. Determine FIN as FIN=(prime*FS)/npts. This ensures that there is no spectral leakage and I have a prime number of cycles in the waveform.
Here is my code:
primes = '(29 53 79 103 131 157 181 211 233) ;prime numbers determined for FIN from 1GHz-9GHz
;set variables for dft
npts=float(256)
FS=float(10G)
TS=float(1/FS)
x=4                                          ;choose the fifth frequency, 5GHz
prime=float(nth(x primes))
FIN=float((prime/npts)*FS)
TIN=float(1/FIN)
a=TIN*1e15 ;this is to round off TIN and set a precision value upto a set number of decimal placez
b=round(a)
TIN=b/1e15
t1=10*TIN                  ;where to start strobing from
t2=float(t1+npts*TS)  ;last point to be strobed
analysis('tran ?start 5*TIN ?stop t2+5*TS ?skipstart t1 ?skipstop t2 ?strobedelay TS/2 ?strobeperiod TS)
desVar(      "AmpIN" 1    )
desVar(      "FIN" FIN    )
desVar(      "R1" 100    )
envOption(
    'analysisOrder  list("tran")
temp( 27 )
run()
fftIN=dft(VT("/OUT") t1 t2 npts "Hanning" 1 1 )
plot(VT("/OUT"))
plot(db20(fftIN))
In the documentation for DFT, it is mentioned that there is a 'coherent gain factor' setting that allows one to 'get consistent results regardless of window type', however, I am not sure how to use this, since the documentation is not clear on usage.
Can anyone shed light on this? Is this variation in magnitude just because of the way DFT is calculated, or is there some setting that I am missing?
