  3. How to set the default Skill path in Ocean?
  • Subscribers 150
  • Views 16093
archive over 19 years ago
Hi all,
Does anyone know what command i can use to set the Skill path in Ocean. I know it can be checked by using getSkillPath() at the Ocean Prompt, but i was unable to find any command to set/change the default path in the Ocean Reference Manual.
Thanks & Regards,
Ghanshyam
Originally posted in cdnusers.org by ghesu
    Look in the SKILL Language Reference manual - since not all SKILL functions would be documented in the OCEAN reference manual.
    The function you want is (surprise, surprise), setSkillPath()
    Originally posted in cdnusers.org by adbeckett
    Yes i found it in the Skill Lang Ref Manual! ~ Thanks Andrew! Appreciate the help!
