  3. How to get VIAS name for a particular technology ?
  • Views 15482
Amar Kumar
Amar Kumar over 10 years ago
To get all the VIAS name for a technology , I am using this :
techID~>viaDefs~>name
The above statement is giving me all the VIAS form the technolog y, but  I want only the vias which can be used in layout.
Ex: when you call the function "leHiCreateVia()" in layout window,a GUI opens.In that GUI list of VIAS are there , which user can select and put in the layout .
So through skill , how can I get those vias name.
OR from list (techID~>viaDefs~>name) , how can I filter the original VIAS.
Please suggest me,
Thanks in advance,
Amar
    Hi Amar,
    cvId=geGetEditCellView()
    cgName=cstGetDefaultConstraintGroupName(cvId "Via")
    split=parseString(cgName ":")
    cgId=if(car(split)=="dsn" then
        cstFindConstraintGroupIn(cvId cadr(split))
      else
        cstFindConstraintGroupIn(techGetTechFile(cvId) cgName)
    validVias=cstFindFirstConstraint(cgId "validVias")->value
    This gets the current constraint group name (as specified on the Editor Options) for Vias, and then looks up that constraint group, and then looks for the "validVias" constraint and retrieves the value.
  • Amar Kumar
    This is exactly what i was looking for and it is working great.
    Many many thanks for the information.
    Really helped me a lot.
    Again thank you so  much.
    Amar
