  3. Removing any metal-1 shape touching contact layer
  • Subscribers 150
  • Views 15112
Cadenceuser15
Cadenceuser15 over 10 years ago
  I am wondering if any one can help me with a skill code which can  remove all the shape (metal-1) touching contact layer (CA).
I tried boolean function but it did not help.
Thanks in advance .
Anil
  • theopaone
    theopaone over 10 years ago
    Do you only want to affect the metal that is in the same cellView as the contact?
    Code is not tested, use at your own risk.
    First, find all the shapes in the cellView that are on the contact layer:
    contShapes = (car(setof( lpps geGetEditCellView()~>lpps lpps~>layerName == "CA"))~>shapes
    Now, go through the shapes and find the metal overlapping the shape and then delete it.
    foreach( shape contShapes
        metalShapes = dbGetTrueOverlaps( geGetEditCellView() shape~>bBox "metal-1")
        foreach( mShape metalShapes
            dbDeleteObject( mShape )
    Ted
