  3. Cadence Git Integeration
  • Views 21324
acook
acook over 10 years ago
All,
I wanted to share an open source project called CdsGit that I've been working on. CdsGit is written in SKILL/SKILL++ and it's goal is to integrate Git into Cadence. I've also started on a basic schematic diff/merge tool.
The repository can be found on GitHub here:
https://github.com/cdsgit/cdsgit
Installation should be fairly straightforward, just follow the README.md steps.
If your interested in contributing, please contact me through GitHub!
  • acook
    acook over 10 years ago +1
    I should also mention I've created several utility classes that can be very useful outside of CdsGit: Binder - bindkey management: https://github.com/cdsgit/cdsgit/tree/master/cdsgit-binder Gridder…
  • acook
    Gridder - A grid based form that uses grids instead of absolute coordinates:
    GenericForm2 - A form that accepts any SKILL function. Allows designer to customize the form look but in the background provides the ability to run a script on library/hierarchically/cell view.
    https://github.com/cdsgit/cdsgit/tree/master/cdsgit-forms
