  3. Pre-save trigger for layout
  • Views 16031
skillvt
skillvt over 10 years ago
Hi
I want to intercept layout save event and run a piece of SKILL code. Idea is to perform some checks on layout, if layout does not meet requirement  save operation will not be performed.
I am performing above mentioned in schematic using schRegPostCheckTrigger. We have multiple projects using both IC5141 and IC614.
    dbRegSaveTrigger is what you want.
  • skillvt
    Thanks for quick reply Andrew ! I am not able to make is work in IC5141, is there any equivalent function I can use to achieve this ?
    No. You have dbRegPostSaveTrigger in IC5141 so you can do something after it was saved, but not before.
  • skillvt
    Alright. Thanks !
