  3. Skill code or cshell script to stream-in multiple gds to...
  • Views 16777
Skill code or cshell script to stream-in multiple gds to different library.
Cadenceuser15
Cadenceuser15 over 10 years ago
  I have multiple gds and I wish to stream in the gds in  multiple library where library name is same as gds_file name.
For example , I have A.gds, B.gds , C.gds .... and I wish to stream A.gds into libarary named "A"  and same way for B.gds goes into library B.
Pleas let me know how should I do it. Any little tips or script will be appreciated.
Thanks ,
Anil
    Hi Anil,
    Using SKILL you would use a sequence of xstInSetField() calls to set up what you want to translate - the various options, and then xstInDoTranslate() to do each import.
    From the UNIX shell you could use the strmin executable (type strmin with no arguments to get simple help on how to use it).
