  3. Hitkit path in a sheet border
  • Subscribers 150
  • Views 15917
Richardv
Richardv over 10 years ago
I would like to insert the Hitkit path in the sheet border.
You know a way ?
thanks
Richard
  • theopaone
    theopaone over 10 years ago
    Please explain what a Hitkit is. Is it a PDK? There may be some variables set by the PDK or are properties on the PDK library. This varies by the PDK supplier. You may have to contact them to find what information is available.
    If you can detect which library is the kit library, use dbGetFullLibPath to get the path to the library directory and then parse that for the installation directory.
    Ted
  • skillUser
    skillUser over 10 years ago
    Hi Ted, I believe that the HitKit is Austria MicroSystems' (AMS) PDK Regards, Lawrence.
  • theopaone
    Thanks, Lawrence. I knew it was from some European fab I just could not remember which one.
  • Richardv
    Yes it's an AMS Hitkit (AMS4.10 ISR9)!
    Richard,
    You probably should ask AMS this question, because it depends on understanding of the setup of their design kit. Even if I had access to the AMS Hitkit myself, I'm not sure I could provide this information in a public forum without potentially violating their license agreement/NDA.
