  3. how to visualize the SKILL code of actions in CIW
  • Views 17469
LuisGutierrez
LuisGutierrez over 10 years ago
Hi all,
I'm wondering how to setup virtuoso to show the skill code of the actions I perform in the interface. For example: if i click on the schematic window it shows in the CIW schSingleSelectPt() or if I remove all probes by pressing zero it shows geDeleteAllProbe().
I have two different projects running in IC6.1.5.500.12 and IC6.1.6.500.6. The older version shows me the code whereas the newer doesn't.
Thanks in advance.
Lucho.
  • skillUser
    skillUser over 10 years ago
    Hi Lucho/Luis,
    Use Options -> Log Filter , in this case you are interested in "Accelerated input (menu & bindkey commands, form and field value settings and callbacks etc.)
    Best regards,
    Lawrence.
  • LuisGutierrez
    Thanks a lot skillUser !
