  3. Assura Label Checking - geomGetUnTexted (or similar)
  • Views 945
resngc
resngc over 10 years ago
The goal is to display error markers around regions of specific layers that do not enclose the origin of a text label. The geomGetUnTexted command was tested but appears to fail to perform its described function; from the Assura 4.1 Command Reference:
geomGetUnTexted
[outLayer=] geomGetUnTexted( inLayer textLayer string [string ... ] )
Description
Selects polygons from inLayer according to the absence of a specified text string of textLayer. Polygons are not selected if the origin of the text string is over the area of the polygon, on any of its edges, or on any of its corners.
If you omit string, geomGetUnTexted selects any polygon of inLayer with no text string.
Arguments
outLayer
Output polygon layer name.
inLayer
Input polygon layer name.
textLayer
Original layer containing text strings.
string
One or more text strings, each enclosed   in quotation marks. To select a polygon, you must specify one or   more of the text strings on the textLayer. The   polygon is selected if the text string origin is not on the polygon of the   input layer.
The characters used in text strings can be   any characters allowed in a label. You can also use the asterisk wildcard   character to select text strings (see Using Wildcards in   Assura for more details on using wildcards).
Each text string can have multiple   instances on different polygons. A single geomGetUnTexted rule selects all   polygons on the specified layer except those with the specified text string.
You can use multiple geomGetUnTexted rules to deselect polygons on different layers with same the specified text string. You can also use multiple geomGetUnTexted rules to deselect a single polygon on an input layer many times according to different text strings.
Omitting the string parameter, contrary to the documented note, causes the Assura run to end abruptly with an error indicating that the string is required: ERROR Require text string in geomGetUnTexted(). Running the command with the string set to match the label text causes the input layer to be selected even when the label origin is contained within the shape; the negated situation was also tested, where the string was set to intentionally mismatch the label text, and the input layer was still selected. Why does this fail?
Is there an Assura command that simply selects label origins? Perhaps something similar to geomOverlap that selects shapes on a layer that overlap a specified text layer origin?
  • resngc
    Resolved. The parameter provided for textLayer was defined as a layer, and not as text. The text layer, if defined under a layerDefs call, must be created using text(layerName layerType), and not layer(layerName layerType). The documentation does not make this explicitly obvious.
