  3. transistor parameters
  • Subscribers 150
  • Views 15619
RobertoD
RobertoD over 10 years ago
I'm trying to figure out how to extract the main parameters of a transistor instance with a skill call (like w, l, m...)
It is easy to extract operating point information with OP(instance) or model related parameters with MP(instance parameter)
, but what if I want to know the value of something which is instance related, like for example w,l, m ... ?
Roberto
  • theopaone
    theopaone over 10 years ago
    The parameter values are properties on the instance.
    If the value is the same as the default value from the CDF, the value may be nil (unless storeDefault is set to true on the parameter) where you have to get it from the CDF.
    instId~>w
    instId~>l
    instId~>m || cdfGetInstCDF(instId)~>m->defValue
    Ted
