  3. Executing VIA form without displaying
  • Views 15631
DannyRitt
DannyRitt over 10 years ago
I am using Cadence solution 11707124 code to execute Auto-Via form.
I am iterating through many overlapped shapes, placing VIAs on the intersections.
The problem is that the form is open and close per iteration (VIA Placement)
Is there a way to execute the form without displaying it?
Danny
Solution # 11707124
---------------------------------------------------------- procedure(CCSmyCreateAutoVia(cvId point) let( () hiRegTimer(" hiGetCurrentForm()->viaMode->value= \"Auto\" hiGetCurrentForm()->rodAutoName->value= t hiToggleEnterForm(hiGetCurrentForm() ) " 2) preXY(point) finishEnterFun() leHiCreateVia() );let );procedure CCSmyCreateAutoVia procedure(CCScreateAutoVia(point @key (cvId geGetEditCellView()) ) let( () unless(cvId && cvId~>objType=="cellView" error("Please pass a valid cellview ID\n") );unless hiRegTimer("finishEnterFun()" 4) CCSmyCreateAutoVia(cvId point) );let );procedure CCScreateAutoVia
    Not really, no. You should contact customer support to request a non-UI SKILL API for this.
  • DannyRitt
    Thanks Andrew, I'll contact technical support.
  • Yanhong
    Yanhong over 8 years ago in reply to DannyRitt
    when I use the code, I noticed that the first time when the via is generated, it is using all via variable settings from the defaults, such as the viaMode is single instead of auto, therefore the viaDef type is not right. But, when I run the script again, then it does all right. Do you have the same issue? How to solve it?
    Andrew Beckett over 8 years ago in reply to Yanhong
    In IC617/ICADV12.3 there are functions such as viaGenerateViasAtPoint which do this, so I'd use those rather than trying to coerce the UI function into doing what you want. This is a recent post which covers this: generating via at given point
