  3. Skill code execution time
  • Views 18741
ssarik
ssarik over 10 years ago
hi,
What is the best/most accurate way to measure the execution time of a skill/skill++ code.
Thanks-Shahbaz
  • skillUser
    skillUser over 10 years ago
    Hi Shahbaz,
    The answer is almost in the question.  Use the "measureTime()" function:
    measureTime(
      g_expression ...
    => l_result
    Description
    Measures the time needed to evaluate an expression and returns a list of four numbers. This is a syntax form.
    The first number is the amount of user CPU time in seconds devoted to the process.
    The second number is the amount of CPU time used by the kernel for the process.
    The third and most significant number is the total elapsed time it took to evaluate the expression in seconds.
    The fourth number is the number of page faults that occurred during the evaluation of the expression.
    Also the measureTime function accepts a second argument (undocumented above) which I believe is the number of iterations to call the expression, so that an average time of the execution can be derived.  For example:
    measureTime(plus(2 2))
    (0.0 0.0 4.053116e-06 0)
    measureTime(plus(2 2) 1000)
    (0.0 0.0 1.907349e-06 0)
    Hopefully this is what you were looking for?
    Lawrence.
  • ssarik
    Thanks Lawrence!
  • dmay
    dmay over 10 years ago
    I would also add that if you have a Skill Development license (skillDev), then the Skill Profiler is a great tool for tracking down where the time is spent in a procedure. It is available in the CIW->Tools->Skill IDE in 6.1.6 and in CIW->Tools->Skill Development (if I remember correctly) in older versions of Cadence. The profiler tracks the time or memory usage in all of the code, not just the top calling function (like measureTime).
    Derek
