  3. Via create options save or load
  • Views 15532
psill000
psill000 over 10 years ago
Is there a way to save or load the via create options at start up or during a cadence session?
Paul
    Paul,
    Which via create options are you talking about, and which version are you using?
  • psill000
    Sorry about I forgot to include the info
    12.1-64b.500.13
    The create via from the pull down menu, leHiCreateVia()
    When the option gui is pulled up I would like to have my specified vias defined as the vias of choice to use
     and possibly the other via create option in the gui:
    Override parameters
    Create in route
    Extend Enclosure Beyond Overlap
    Fill overlap
    Paul
    Paul,
    Which vias are displayed is controlled by the validVias constraint in whichever constraint group you have set for vias (see Options->Editor). You can also initialise that with cstSetDefaultConstraintGroupName() - see the documentation for more details.
    The other options can be set with:
    leSetEnv("autoViaOverrideVariantParameters" t)
    leSetEnv("viaCreateInRoute" t)
    leSetEnv("viaExtendEnclosureBeyondOverlap" t)
    leSetEnv("viaFillEnclosureOverlap" t)
    leSetEnv("viaFillPolygonalOverlap" "Partially") ; or "Fully"
    not sure if you wanted the last one.
