  3. ciConResetParams
  • Views 14223
ciConResetParams
fishbulb15
fishbulb15 over 10 years ago
I am attempting to (in SKILL) clear our specific process rule constraint parameters from a constraint.  This is what I mean:
In this list of lists: constraint~>parameters, I would like to remove (or set to default) specific parameters that were previously set.
Currently the ciConResetAllParams(constraint) works, for what I am attempting, but the problem is that it clears out EVERYTHING.
I have tried to run ciConResetParams(constraint list("viaNumCuts" "layerWidths")) without it resetting these parameters.
Any Ideas?
    I'm not sure how to make this work either. Unfortunately the documentation is severely lacking - it seems no matter what I pass to ciConResetParams it returns nil (indicating a failure).
    So please contact customer support - we should work this through with R&D and get the docs improved too.
