  3. question about loading functions
  • Subscribers 150
  • Views 16310
archive over 19 years ago
Hi,all: I am new to Cadence, and right now I am learning how to use skill language. I typed one file I found online and saved it to /home/user/1.il. The file is as following: procedure( rectanglefury( num_rect ) cvID = geGetWindowCellView() for( i 1 num_rect llx = random( 1000 ) lly = random( 1000 ) urx = random( 1000 ) ury = random( 1000 ) x = random( 10 ) if( ( x > 6 ) dbCreateRect(cvID list("L0" ) list( llx:lly urx:ury ) ) ) if( ( x>3 && x"L1" ) list( llx:lly urx:ury ) ) ) if( ( x "L2" ) list( llx:lly urx:ury ) ) ) ) ) then I go back to load this to cadence,using: >load( "/home/user/1.il") but I always got error as following: if( ( x > 6 ) dbCreateRect(cvID list("L0" ) list( llx:lly urx:ury ) ) ) SYNTAX ERROR found at line9 column 26 of file /home/user/1.il *Error*lineread/read:syntax error encountered in input ***Error in rountine load: Entering new debug toplevel due to error Can anyone tell me what is wrong with this?Thanks in advance! --sophia
Originally posted in cdnusers.org by sophia_song
    Rather hard to tell, since the formatting has got completely messed up.
    If I cut and paste the above, into a file, I don't get any syntax errors, Did you try looking at line 9 column 26 of your file?
    Originally posted in cdnusers.org by adbeckett
    Hello,Andrew:
    Thanks for your response.
    Yes, I did. Line 9 column 26 is this line : if( ( x > 6 ) dbCreateRect(cvID list("L0" ) list( llx:lly urx:ury ) ) ) and the column is ' ( ' inbetween ' dbCreateRect(cvID ' . Can you check on this again? ----sophia
    That looks perfectly OK. Is there a space between the dbCreateRect and the open parenthesis?
    The other thing to try is to do (in UNIX):
    cat -vet code.il
    to look if there are any strange characters in the file.
    1.
    if( x > 6 then
    dbCreateRect(cvID "L0" list(llx:lly urx:ury))
    ); if
    2.
    if( x > 3 && x < 6 then
    dbCreateRect(cvID "L1" list(llx:lly urx:ury))
    ); if
    if there is only one condition, change it to when instead of if.
    Try to see if it works.
    Originally posted in cdnusers.org by mvu
