  3. How do I put array at the place I want
  • Subscribers 150
  • Views 14788
archive over 19 years ago
Hi,all: I want to put a lot of small squares in the ground plane, but not the trace where current flows. Please take a look at the picture I attached here, it may help you understand me. my question is now 1) can I use skill language program this? (2) is this the only way I can do? I can use chop function but since I have a lot of trace, chop function isn't so practical. (3)if i can use skill, then which function I should use? or I need to make one by my own? Thanks a lot!!---sophia
Originally posted in cdnusers.org by sophia_song
1.pdf
    archive over 18 years ago
    There are functions in ASSURA to create such type of dummy fills.
    Originally posted in cdnusers.org by sagirameshraju
