  3. CDF modelname as parameter using pPar
  • Subscribers 148
  • Views 18822
keving
keving over 10 years ago
I'm trying to have an instance where as well as having e.g. width/length as pPar, that the model name would be pPar type as well.
The model name could be of two different vt-types, e.g. svt, ulvt.
The modelname field in the PDK is not available for edit directly when you "q" the properties of the device.  As an experiement, I have made a copy of the PDK instance into a test library and edited the CDF to make the model name editable.
This works ok so far, but now have error that when I try to netlist schematic, it reports can not pass model name hierarchically for instance "M0"
any help would be appreciated on this?
Kevin
    Kevin,
    This should work fine. I just tried it with gpdk45 - from
    I did the following:
    1. Took a copy of the cell nmos1v into my own library
    2. Tools->CDF->Edit CDF, set the CDF type to Base, and picked mylib/nmos1v. Then I changed the "model" field to be editable
    3. I created a schematic for a cell called subblock, and placed two instances of mylib/nmos1v. On one instance I set the model to be pPar("themodel") and on the other I set it to pPar("othermodel")
    4. I did Create->CellView->From CellView to create a symbol (and the CDF) for subblock.
    5. I then used Tools->CDF->Edit CDF (in Base CDF mode) to set the default value for themodel to be nch, and the default value for othermodel to be nch2.
    6. I created a schematic for "topblock" and placed two instances of subblock. One I left at default and the other I set the two model parameters to be nch3 and nch4.
    I netlisted this in ADE and got:
    // Library name: mylib
    // Cell name: subblock
    // View name: schematic
    subckt subblock a b vss
    parameters othermodel="nch" themodel="nch2"
    NM1 (net1 a vss vss) analogmodel modelname=othermodel w=(120n) l=45n \
    nf=1 as=16.8f ad=16.8f ps=520n pd=520n nrd=1.16667 nrs=1.16667 \
    sa=140n sb=140n sd=160n sca=226.00151 scb=0.11734 scc=0.02767 \
    m=(1)
    NM0 (b a net1 vss) analogmodel modelname=themodel w=(120n) l=45n nf=1 \
    as=16.8f ad=16.8f ps=520n pd=520n nrd=1.16667 nrs=1.16667 sa=140n \
    sb=140n sd=160n sca=226.00151 scb=0.11734 scc=0.02767 m=(1)
    ends subblock
    // End of subcircuit definition.
    // Cell name: topblock
    I1 (net2 net3 net1) subblock othermodel="nch3" themodel="nch4"
    I0 (net5 net6 net4) subblock othermodel="nch" themodel="nch2"
    As you can see, it's automatically netlisted the devices as analogmodel (see "spectre -h analogmodel" for more details). This is what should work fine in the simulator (spectre).
    So what was the exact error that you got?
