  3. convert '() to list()
  • Views 3987
loboveena
loboveena over 10 years ago
I am creating a form which has multiple tab fields and want to display only those tabs that meet a certain condition. So the output I get is of type list but in the format '() . The problem I have is providing this list to the ?fields argument of hiCreateTabField() function as it looks for the input in the format "list()" .
Is it possible to convert '() to list() in skill ?
I am aware of the visible/invisible option to do this but this is not what I want.
Veena
    Veena,
    This doesn't make sense. The hiCreateTabField (or indeed any other function in SKILL) doesn't expect anything in list() or '() format. They require list objects, but they don't care how the list was formed. A list is a particular type in SKILL, and the  list() function and '() function are just two of many functions that can construct lists. list() builds a list from the evaluated values in its arguments, and '() creates a literal list with no evaluation - that's the only difference. So converting between the two makes no sense as it's unnecessary and once the list is a created, nothing has any knowledge of how it was created.
    Perhaps if you can describe your bigger problem or provide the code that has the issue, we might be able to give more specific advice?
  • loboveena
    Andrew,
    Thanks for responding.
    The problem was that the ?fields argument was assigned nil. Hence hiCreateTabField failed. I had one more query. Hope I can ask it in the same post.
    I am unable to get the tab names used in the form by providing tab value ?
    I tried the following; Created a sample form; See sample code below;
    1. f=hiGetCurrentForm()
    -- Returns form Id
    2. get(f->tabFld  nthelem(f->tabFld->value f->tabFld->fieldList))
    -- Returns page3 { as third tab was selected in the form) instead of tab name.  Is there anything I am missing here. How do I get the tab name from pagebasename# ?
    Veena
    ;; Usage :: crTabForm('("flow1" "flow4"))
    procedure(crTabForm(flowTypeL)
    let( ( libFld cellFld viewFld lcvBB o1CellFld o2CellFld o3CellFld o4CellFld tabFld1 tabFld2 tabFld3 tabFld4 tabFld5
    form (fSize 620:500))
    ;; Basic Setup tab
    libFld = hiCreateStringField(
    ?name 'libFld
    ?prompt "Library"
    cellFld = hiCreateStringField(
    ?name 'cellFld
    ?prompt "Cell"
    viewFld = hiCreateStringField(
    ?name 'viewFld
    ?prompt "View"
    o1CellFld = hiCreateStringField(?name 'o1CellFld ?prompt "Output Cell")
    o2CellFld = hiCreateStringField(?name 'o2CellFld ?prompt "Output Cell")
    o3CellFld = hiCreateStringField(?name 'o3CellFld ?prompt "Output Cell")
    o4CellFld = hiCreateStringField(?name 'o4CellFld ?prompt "Output Cell")
    ;;Setup
    tabFld1 = list(
    list(libFld 20:75 440:30 100 )
    list(cellFld 20:105 440:30 100 )
    list(viewFld 20:135 440:30 100 )
    ;;Flow1
    tabFld2 = list(
    list(o1CellFld 30:210 440:30 100 )
    ;;Flow2
    tabFld3 = list(
    list(o2CellFld 30:210 440:30 100 )
    ;;Flow3
    tabFld4 = list(
    list(o3CellFld 30:210 440:30 100 )
    ;;Flow4
    tabFld5 = list(
    list(o4CellFld 30:210 440:30 100 )
    flds_to_be_displayedL=list(tabFld1)
    tabs_to_be_displayedL=list("Setup")
    foreach(f flowTypeL
    when(equal(f "flow1")
    flds_to_be_displayedL=append1(flds_to_be_displayedL tabFld2)
    tabs_to_be_displayedL=append1(tabs_to_be_displayedL "flow1")
    when(equal(f "flow2")
    flds_to_be_displayedL=append1(flds_to_be_displayedL tabFld3)
    tabs_to_be_displayedL=append1(tabs_to_be_displayedL "flow2")
    when(equal(f "flow3")
    flds_to_be_displayedL=append1(flds_to_be_displayedL tabFld4)
    tabs_to_be_displayedL=append1(tabs_to_be_displayedL "flow3")
    when(equal(f "flow4")
    flds_to_be_displayedL=append1(flds_to_be_displayedL tabFld5)
    tabs_to_be_displayedL=append1(tabs_to_be_displayedL "flow4")
    printf("%L\n" flds_to_be_displayedL)
    tabFld = hiCreateTabField(
    ?name 'tabFld
    ?fields flds_to_be_displayedL
    ?tabs tabs_to_be_displayedL
    ?tabPlacement 'top
    ?value 1
    form = hiCreateAppForm(
    ?name 'form
    ?formTitle "Custom Utility"
    ?dialogStyle 'modeless
    ?buttonLayout 'ApplyCancel
    ?initialSize fSize
    ?fieldFocus 'allTypein
    ?fields list(list(tabFld 1:5 620:500))
    hiDisplayForm(form)
    t
  • loboveena
    Could you let me know if it is possible to get the tab names by providing the tab value in a given form.  Am I missing something while creating the tabField ?
    Veena
    Hi Veena,
    There are several ways to achieve this. One is to rely on a property
    on the form that is named such that it suggests it should be treated as
    private and liable to change:
    pageName=nthelem(f->tabFld->value f->tabFld->_hi_altNames)
    for example, this would give page_flow2.
    Personally I don't like this. For a start, it depends on a private property
    (the underscore at the beginning is the clue), plus it's encoded - so
    spaces get collapsed to underscores, and so on.
    So what I would do is store your tab names on each page. After the
    hiCreateTabField line in your code, I'd add:
    foreach((page tab) tabFld->fieldList tabs_to_be_displayedL
      get(tabFld page)->myTabName=tab
    Now when you want to retrieve the tab name:
    tabName=get(f->tabFld nthelem(f->tabFld->value f->tabFld->fieldList))->myTabName
    so this would return "Setup", "flow1" etc.
  • loboveena
    This is awesome. This logic never stuck me. Thank you very much.
    Veena
