  3. Change all toggle fields in a form using single selecti...
  • Views 16057
Change all toggle fields in a form using single selection
gaurc
gaurc over 10 years ago
I want a form like this...
Select all  (tick box)
A (tick box)
B (tick box)
C (tick box)
D (tick box)
when I tick (make true) "Select all field" all the below fields (A B C D) should be selected and when I remove tick (make nil) all these fields (A B C D)  should be unselected.
Using hiCreateToggleField function how can I do this? What are the other functions involved?
    Try this:
    /* abToggleForm.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Feb 23, 1999
    Modified   Sep 16, 2009
    By         A.D.Beckett
    Functions for creating a variable list of toggles
    with all and none toggles. The list of toggles is
    in a scroll region.
    Attempted to make it resizable, but this rather contradicted
    with the scroll region, so left the scroll region in the form
    instead.
    Three main entry functions:
    abCreateToggleForm()
    abToggleFormGetSelected()
    abToggleFormSetSelected()
    Example:
    procedure(myToggleCB(form)
       printf("Selected Files were:\n")
       pprint(abToggleFormGetSelected(form))
       newline()
    hiDisplayForm(
      abCreateToggleForm(
         ?name 'myTogForm
         ?textList getDirFiles("/bin")
         ?prompt "Choose Files"
         ?callback 'myToggleCB
    SCCS Info: @(#) abToggleForm.il 09/16/09.12:22:46 1.5
    *                abCreateToggleForm(?name s_formName                *
    *              ?textList l_textitems ?prompt t_prompt               *
    *         [?formTitle t_formTitle] [?value b_defaultValue]          *
    * [?yStep x_yStep] [?formWidth x_formWidth] [?xPosition x_position] *
    *          [?toggleHeight x_height] [?toggleWidth x_width]          *
    *                      [?callback s_callback])                      *
    *     [?formType 'options/'nonoptions] [?buttonLayout 'OKCancel]    *
    *      Create a form full of toggle items, with an all or none      *
    *       button. Must provide at least the symbol for the form       *
    *              name, the list of items, and a prompt.               *
    procedure(abCreateToggleForm(@key
            (name nil)
            (formTitle "")
            (textList nil)
            (prompt "")
            (value t)
            (yStep 20) (formWidth 300)
            (xPosition 220) (toggleHeight 200) (toggleWidth 250)
            (callback nil)
            (formType 'nonoptions)
            buttonLayout
        let((toggleList togName (toggleNumber 0)
                (yPosition 0) topLabel allButton noneButton
                scrollRegion separator form)
            ; delete any existing form
            when(boundp(name) && symeval(name)
                hiFormCancel(symeval(name))
                hiDeleteForm(symeval(name)))
            ; Default button layout
            unless(buttonLayout
                buttonLayout=if(formType=='nonoptions 'OKCancel 'HideCancel)
            ; create the label at the top of the toggle list
            topLabel=hiCreateLabel(?name 'label ?labelText prompt)
            ; create the toggles for each entry in the textList
            toggleList=foreach(mapcar text textList
                ; create the name of the toggle
                togName=concat('toggle ++toggleNumber)
                ; return the first value in the group
                prog1(
                    ; create the toggle and add it onto the list
                    list(
                        hiCreateBooleanButton(
                            ?name togName
                            ?buttonText text
                            ?callback
                            sprintf(nil "abToggleFormOtherButtonCB(%s '%s)"
                            name togName)
                            ?value value
                            ); hiCreateBooleanButton
                        0:yPosition
                        toggleWidth:yStep
                        xPosition
                        ); list
                    ; increment the step
                    yPosition=yPosition+yStep
                    ); prog1
                ); foreach mapcar
            ; add the line and the All and None toggles
            separator=hiCreateSeparatorField(?name 'separator)
            allButton=hiCreateBooleanButton(
                ?name 'All
                ?buttonText "All"
                ?callback sprintf(nil "abToggleFormAllButtonCB(%s)" name)
                ?value value
            noneButton=hiCreateBooleanButton(
                ?name 'None
                ?buttonText "None"
                ?callback sprintf(nil "abToggleFormNoneButtonCB(%s)" name)
                ?value !value
            ; the sroll region itself
            scrollRegion=hiCreateScrollRegion(
                ?name 'scrollRegion
                ?fields toggleList
                ?borderWidth 0
            ; create the form
            form=hiCreateAppForm(
                ?name name
                ?fields list(
                    list(topLabel 0:0 formWidth:yStep*2)
                    list(scrollRegion 0:yStep*2 formWidth:toggleHeight)
                    list(separator 0:toggleHeight+yStep*2 formWidth:0)
                    list(allButton 0:toggleHeight+yStep*3 formWidth:yStep xPosition)
                    list(noneButton 0:toggleHeight+yStep*4 formWidth:yStep xPosition)
                ?formTitle formTitle
                ?formType formType
                ?buttonLayout buttonLayout
                ?callback callback
            ; store various information on the form
            form->numButtons=toggleNumber
            if(value then
                form->numSelected=toggleNumber
            else
                form->numSelected=0
            form
    *            abToggleFormOtherButtonCB(form field)             *
    *  Callback for each toggle (except all or none) on the form   *
    procedure(abToggleFormOtherButtonCB(form field)
        let((numSelected)
            numSelected=form->numSelected
            if(get(form->scrollRegion field)->value
                numSelected++
                numSelected--)
            form->numSelected=numSelected
            form->None->value=numSelected==0
            form->All->value=numSelected==form->numButtons
    *              abToggleFormAllButtons(form value)              *
    *    Utility function to set all the buttons to a specified    *
    *                            value.                            *
    procedure(abToggleFormAllButtons(form value)
        let(((scrollRegion form->scrollRegion))
            foreach(field scrollRegion->fieldList
                get(scrollRegion field)->value=value
    *                abToggleFormAllButtonCB(form)                 *
    *                 Callback for the All button                  *
    procedure(abToggleFormAllButtonCB(form)
        cond(
            (form->All->value
                abToggleFormAllButtons(form t))
            (form->numSelected==form->numButtons
                form->All->value=t)
    *                abToggleFormNoneButtonCB(form)                *
    *                 Callback for the None button                 *
    procedure(abToggleFormNoneButtonCB(form)
        cond(
            (form->None->value
                abToggleFormAllButtons(form nil))
            (form->numSelected==0
                form->None->value=t)
    *                abToggleFormGetSelected(form)                 *
    *  Function that may be used in the form callback function to  *
    *             retrieve all the selected item names             *
    procedure(abToggleFormGetSelected(form)
            foreach(mapcar field
                setof(field scrollRegion->fieldList
                    get(scrollRegion field)->value)
                get(scrollRegion field)->prompt
    *          abToggleFormSetSelected(form promptValList)          *
    * Function that may be used to set (or unset) a list of fields. *
    *   The second argument is a list of lists, with each sublist   *
    *  being the prompt for the field, followed by t/nil to set or  *
    *                       unset the toggle.                       *
    procedure(abToggleFormSetSelected(form promptValList)
        let(((scrollRegion form->scrollRegion) (fieldTable makeTable('fields nil))
                foundField)
                fieldTable[get(scrollRegion field)->prompt]=field
            foreach(promptVal promptValList
                foundField=fieldTable[car(promptVal)]
                if(foundField then
                    get(scrollRegion foundField)->value=cadr(promptVal)
                else
                    warn("No toggle with prompt %L on form\n" car(promptVal))
            t
