  3. ipcBeginProcess() appear to slow down script execution
  • Views 16051
Flaxter
Flaxter over 10 years ago
Hi there,
 I am having a "speed" issue using ipcBeginProcess() command while trying to execute Calibre DRC on given layout. The code I am using is:
CommandLine="calibre -drc -hier _myDrcSetup_"
ipcP=ipcBeginProcess(CommandLine) ipcWait(ipcP
,which gets the job done (approximately 25mins). However, using Calibre GUI or that command sh("calibre -drc -hier _myDrcSetup_") the task is complete in far less time (~9mins).  Calibre set up is all the same in all three cases, am preforming DRC on same layout etc. With ipcBeginProcess Calibre output files are "written" slower and it doesn't seem like it gets the job done and process just "hangs" for a given period of time.
The only reason and I am not using sh() is that Calibre task is not done if parent linux terminal is accidentally closed and also I am afraid it might mess up the script flow. ipcBeginProcess()+ipcWait() seems more civil way to solve the problem.However, such slow execution is not applicable.
    I can't see a good reason for this. So please contact customer support. One thing you might want to try is redirecting the stdout of calibre if it is producing a lot of output data:
    CommandLine="calibre -drc -hier _myDrcSetup_ > ./myCalibre.log"
    See if that helps? Since with IPC it allows you to read the results with ipcReadProcess(), you may be flooding the input buffer if there's a lot of stdout from the child process. If you're not using that output, redirecting to a log file may make more sense. Or alternatively use:
    CommandLine="calibre -drc -hier _myDrcSetup"
    ipcP=ipcBatchProcess(CommandLine "" "./myCalibre.log")
    ipcWait(ipcP)
  • Flaxter
    Hi Andrew, both of this solutions worked properly. Thanks for helping out.
