  3. Problems with callbacks in Window Forms
  • Views 15564
JMPerdomo
JMPerdomo over 10 years ago
Hi, I am trying to display my form in a window in order to have the maximize/minimize option. Bu when I launched as a window form, all my callbacks stop working.
This is a extract of my GUI code:
; Create Tab field
; Note: attachment fields must be made for each field of each tab or it will not work
TabField = hiCreateTabField(
?name 'TabField
?fields list( Options_FieldList DocData_FieldList Question_FieldList)
?attachmentList list(
list(
hicTopPositionSet | hicLeftPositionSet | hicRightPositionSet
list(
list(hicTopPositionSet | hicLeftPositionSet | hicRightPositionSet | hicBottomPositionSet)
?tabPlacement 'top
;?callback 'SampleTabFieldCB
?tabs list( "Options" "Document Data" "Questions" )
?defValue 1
; Create Button field
ButtonField = hiCreateButtonBoxField(
?name 'ButtonField
?choices list("Generate" "Save" "Cancel" )
?callback list("CallBack_Generate()" "CallBack_ButtonSave()" "CallBack_ButtonCancel()")
?prompt " "
; ?attachmentList list(hicTopPositionSet | hicLeftPositionSet | hicRightPositionSet | hicBottomPositionSet)
; Windows Layout
; Calculate Window size
WindowHight = WindowHightMin
TabHight = WindowHight+10
TabSize = (MaxWide+10):TabHight
WindowSize = (MaxWide +30):(WindowHight+30+30)
;WindowSize = 500:500
;WindowSize = MaxWide:500
ButtonFieldSize = 200:40
; Fields Layout
; Set FielList and positions
Main_FieldList = list(
list(TabField 10:10 TabSize)
list(ButtonField (MaxWide-180):(TabHight+10) ButtonFieldSize 10)
; Create Form
ParamsForm = hiCreateAppForm(
?name 'Menu_LCR
; ?fields list( list( TabField 10:10 TabSize ))
?fields Main_FieldList
?formTitle "Layout Review CheckList"
?buttonLayout 'Empty
; ?callback "LRCMenuRun()"
?minSize WindowSize
; ?maxSize WindowSize
?initialSize WindowSize
; ToolTips
;ParamsForm->FloatField_Jump->hiToolTip = " Size of the Jump/Stretch to Do"
;ParamsForm->ToggleField_Option->hiToolTip = "Control if the figures will be stretched"
;ParamsForm->RadioField_Direction->hiToolTip = " Direction to do the Jump/Stretch"
; Load last checklist if data is available
(if LRCMenu_LastCheckList_Questions != nil then
LoadLastChecklist(?InitialForm ParamsForm)
; Launch form
;hiDisplayForm( ParamsForm )
 Window = hiCreateWindow('default "form" "MyApp" "" nil ParamsForm)
 hiDisplayWindow(Window)
Can you tel me if I am doing something wrong?
Best regards!
  • skillUser
    skillUser over 10 years ago
    Hi Juan,
    My guess is that your callback is using geGetEditCellView() or some similar function to get the design dbId or design window Id, and now that the form is in a window the current window is the one that contains the form (and not the design).  If this is the case, try using hiGetWindowList() to take a guess at which window is the one to use for the callback.  Or you could store the window Id or dbId of the design on the form structure when you invoke the form from a design window, then there is no ambiguity, the callback should then just 'read' the design window ID or dbId from the form structure.
    Hope this helps!
    Lawrence.
