  3. how to create "veriloga" view from the "symbol" by skill...
  • Views 4701
how to create "veriloga" view from the "symbol" by skill code
fatcat1206
fatcat1206 over 10 years ago
Hi All
Does anyone knows how to create "veriloga" view from a "symbol" by skill script?
Which function should I call?
I know from the GUI, it's quite straight forward: create-->Cellview-->From Cellview.
unfortunately, the log file does not tell the calling function :(
I want to write a script that can create a verilogA-stimuli for the DUT. Currently, I am blocked by creating the veriolga view.
Best Regards
Yi
  • fatcat1206
    Hi All
    I just tried it out, below is the function. I assign the value for "_viewType" to indicate that I want to create a veriloga view.
    the remaining issue is that it would open a window, which I do not need when running my script.
    deNewCellView(
    t_libName
    t_cellName
    t_viewName
    "text.veriloga"
    g_winSepc
  • skillUser
    skillUser over 10 years ago
    Hi Yi,
    Take a look at Solution Article 11043590 and also Solution Article 11116718.
    Hopefully the above will answer your question.
    Lawrence.
  • fatcat1206
    Hi skillUser
    Thanks, it's indeed what I am looking for.
    The function I found before can only generate the veriloga file, the pin definition is not there.
    Best Regards
    Yi
  • YiWang
    YiWang over 7 years ago in reply to fatcat1206
    What a coincident!!
    This post I made 3 years ago gives me the exact solution when I need to create an empty systemVerilog Cell view today.
    To find the valid viewType, one method is calling the  _schGetValidViewTypes().
