  3. How to netlist using SKILL?
  • Subscribers 150
  • Views 17072
archive over 19 years ago
For a given config view, i tried the createNetlist() command, after which OCEAN displays the path to the .scs file which should indicate that the config view has been renetlisted successfully. But that is not the case. The simulation refers back to the old netlist file. Does anyone know how to re-netlist a design (schematic/config view) using SKILL?
Originally posted in cdnusers.org by ghesu
    You can always use createNetlist(?recreateAll t)
    Originally posted in cdnusers.org by adbeckett
    In 446/ic50 days the ocean> skill subset did not support that command.. you had to be running icfb or icms in order to recreate the netlist..
    jbd
    Originally posted in cdnusers.org by jbdavid
    That explains a lot. Thanks!
