  3. Reading ouput results from results database
  • Views 16498
frasheed
frasheed over 10 years ago
I wrote a small script to read the results database for a history (using axlReadResDB). I tried to read the documentation to extract the output names and results for them. My goal is to read every test in this results database and then for every corner I need to read the output parameter name and its value.
for example:
rdb->test1->corner1->output1
rdb->test1->corner1->output2
rdb->test2->corner1->output1
any hint or solution for to do this ?
Farhan
    Farhan,
    Please look at:
    At the end of the script, you'll see how the resultsDB handle is used - it iterates over the points, then the corners, etc etc.
  • frasheed
    Thanks for the fast response, that code is helpful :)
